copious
I thought some of the resident arcade experts might know the answer to this. As some are aware I am resurrecting a DL cab to play both DL and SA on Daphne using the HD versions just released.
I have everything running and for video I'm using an ArcadeVGA and a WG47xx monitor. The games play great and the colors are excellent. The only issue I see is that on one or two scenes the monitor gets sections that look like the sync is off. It's the high graphic areas. Like in DL when the attract mode shows Dirk approaching the spinning balls. The area where the balls is gets torn for until the scene is over.
Anyone ever see this? I had to use the amp with this monitor but I do have the H/V on the -H combined and I can split it out.
