AceJay
Hey everyone - I have 2 DanceManiax machines. One came with 1st, 2nd, and Append Jparadise, with Append installed. I'm getting RTC issues/error 605 on it, so I went and swapped out the entire 573 for the 2nd machine's 573. That one has 2ndMix installed.
So, the problem is, I can't upgrade 2nd to Append now. I get an error (175/176) saying (in Japanese) "Since the Security Cart and PCB's Certificate numbers do not match, please turn off the machine and insert the correct security cart." This one matches the label on the PCB. When I then put in the cart with that number I get another error (121) that says that the Security cart isn't loading/interacting/working or something.
Is the game normally supposed to boot to Onboard memory/Flash rom or to the CD?
So if you flip the boot Dip switch (4) to OFF, meaning to CD, and swap out the upgrade mix disc and its security cart, shouldn't that install the upgrade?
Holding down the Test/Service buttons did noting.
Any ideas? I have all 3 manuals.
