Fatsquatch
Update #2
I've got in touch with a Stern tech about the damage to my machine, and was told the following:
This is what my tech had mentioned to me when discussing what might have happened to cause such damage.
My tech had installed a new CPU board that he had available, and other than the DMD being dead, he said the machine functioned and played just fine.
Any number of things could of happened to the circuit boards in your game when the flash lamp socket hit the file cabinet assembly. I'm suspecting the 20V source for your flash lamp was induced into the switch matrix (Q6) and possibly the +5 V circuit.
Do you have another CPU board you can swap into the game to verify whether or not there's any other problems? If the fault is only with the CPU board and not display controller or I/O boards, I would start swapping the IC's that are in socket. (U209, U210, U212, and U213 if in socket) U213 is usually the first IC to fail causing reset issues.
