Dag Wire Quick Connection
Tython
Donor 2025
Central Point, Oregon
Hello,
Recently started working on some monitors, such as K7000s. I have a few where the dag wire was never cut and others where there is a quick connection. What recommendations are best for quick connect options, or is soldering always best?
I also have a chasis where the dag wire is connected to the frame with a screw, and has another wire to the dag, is this OK as well?
Thank you
Usually the neckboard has two ground wires coming out of it. One of them is hooked up to the chassis frame with a screw, the second wire is soldered onto the dag wire on the tube.
I usually cut the black wire going to the dag wire a few inches from the neckboard, and to hook it up again, twist the wire together and put on a wire nut, but I've seen others put on a spade quick connect. I'm lazy, so the wire nut usually wins out.
