DesertDweller88
- Joined
- Nov 22, 2024
- Messages
- 83
- Reaction score
- 64
Holy hell this was challenging. So I picked up a D9400 monitor and chassis that I plan to use for my dynamo HS-9 Marvel Vs Capcom 2 cabinet.
Seller mentioned that him and others tried to get this monitor working but was at a point that he just wanted to get rid of it. He also mentioned that the chassis would click but nothing else.
Decided to not power the unit and try to find as many issues as possible.
Repair Notes:
1. Replaced shorted out HOT (Q207)
2. Replaced shorted out Q206, previously read false open diode readings for D209, D210, D212, ZD201, D208 due to Q206 being shorted between gate, drain and source pins.
3. Placed transistor isolator plastic behind IC301, this was causing ic301 pin 4 to have connection to ground, causing D517 to be reversed biased and letting the magic smoke out. Of course I didn't know this until first turning on the unit and seeing smoke come out of D517. This lead me down a pretty big rabbit hole, story below if interested.
4. Replaced D517
5. Tube is up and running now, but is in definite need of a cap kit.
Jumped Down A Rabbit Hole
After checking the power supply area I decided to power the unit up. After flipping the switch, the power supply clicked and the green LED came on but then immediately shut off and came back on. The second time this happened magic smoke started coming from D517 near T501. Looking into it, D517 in circuit read shorted with the cathode leading to T501 and the anode trace pathway leading to pin 4 of the vertical amp IC301.
Repair Notes:
4. Replaced D517
- Looking at the schematics the only way D517 is burning up is if it's being reversed biased
- Checked for shorts from pin 4 to the other IC301 pins, no shorts.
- Followed traces, not finding any other path that could be causing this issue.
- Found that Pin 4 somehow has continuity to ground......wait what???
. How can this happen if pin4 is not shorted to any other of the IC301 pins. Checked D517 and it also showed continuity to ground - Even more confusing, with D517 removed, both solder pads still showed continuity to each other....WHAT???!! This means that both cathode and anode sides are connected to ground.
- Spent an hour checking all of the related circuits and looking for shorted components to ground.
- I decided to un solder jumper J114 that connects pin 4 of IC301 to D517 area. Bingo! D517 anode and cathode solder pads are no longer showing continuity.
- This meant something in the IC301 pin 4 circuit was connected to ground.
- I removed IC301 since I couldn't find anything out of the norm with the solder location.
- Doing so pin 4 solder pad no longer showed continuity to ground. For the hell of it I replaced IC301 but it should continuity with ground again........
- BINGo.....Sigh...the people before removed IC301 and removed the back insulator and reinstalled it without one. This caused the short to ground once a screw and bolt are used to hold it up against the heat sink.
- Reinstalled IC301 with back isolator, though used a zip tie to hold it against the heatsink instead.
- Reinstalled jumper J114 and replaced the burnt out D517 diode.
- Fired up the unit and was pleased to see the X-Men vs Street Fighter intro
