D9200 Zooming In and Out
total
Donor 2017
Minnesota
I've got an odd issue on my D9200 in a Silver Strike Bowling. The monitor basically looks like it's slightly zooming in and out while playing. I did a cap kit on it and the issue is still there. Reflowed a majority of both the chassis and neckboard too.
I did have to adjust the colors and what not manually as the picture was dark originally but the settings are holding, so I don't think the IC103 is shot. I've adjusted the brightness down and played with the flyback quite a bit to see if it's sometime setting related.
I'm kind of at a loss here. Anyone got any recommendations on what to check? Once the monitor warms up the problem is less noticeable, but it is still there.
Finally got around to posting a Youtube video of my work on this monitor. If you've seen cap kits done, you've seen my video. However you missed out on my wit, so it might still be worth the watch. :D
Anyways here is the video:
If you want to skip right to the part where you can see the issue first hand click here.
If anyone can provide any help I'd appreciate it.
