D9200 Yoke
Oryk Zinyo
Bremerton, Washington
Can anyone help me out by taking readings off of the yoke of a D9200? I have one here that I believe is shorted but I want to make sure. Currently I am seeing 2.7 ohms and 0.2ohms.
Thanks,
OZ
Not the Yoke
Yoke's fine.
your ohms is correct
An open winding in a yoke will show open with the ohm meter
or burned mark when you remove the yoke and you can see it in most case's.
Loss of Width?
HS you need the 170v's
measured at R462 a half watt resistor
See if R462 is open
Heres a thread with more details
and over kill on his parts list but all need to be checked.
Check the connection on the coil
try L402 and resolder
and c438
Good Luck!
http://forums.arcade-museum.com/showthread.php?t=163803&highlight=r462
