Alright...so I bust out a full cap kit on my D9200 as I was still getting some waves (slight) when i was done with the Bob Roberts kit (which only included like 12-16 caps). I replace every cap on the main chassis and neck board except the filter cap.
I was 1 cap short... C905... I didn't notice until I'd already pulled it, so i put it back in and finished up with the rest of the caps. Of course when i soldered all the caps in to place I failed to remember to re-solder C905 back in place.
I put the chassis in... plug everything in... fire it up and I see GT Fore come up on screen but the bottom of the screen didn't appear to sync right... there was also a pulsing going on... I dick around trying to see if I can get the picture to stabilize and in the process I notice the screen collapse to center... the image was simply a vertical bar about 2" wide that would pulse on and off. I turn off the cab, pull the chassis and check it out. That is when I notice C905. I solder C905 in and prayed... that was the only thing I could see wrong ...
When I put the chassis back in I fired it up... first thing I noticed was the flyback didn't squeal as much (as it did when having the sync issue)...I was pleased at first...then I check the image... there is no image.
BAH! I am getting nothing on screen. I can hear the flyback working... I can see the neck glow... but nothing.
What did I manage to screw up by not soldering in the c905? The cap is right next to the flyback...
Help!
Help!
