D9200 video card help...
keithsarcade
St Peters, Missouri
Finally tore into this D9200. The small video card (where the video connections go to) has some serious heat related damage in the lower LH corner. I think I can resurrect it (though I'd prefer to just find another one). What I'm looking for is a hi-res. photo of the solder side, particularly the bottom portion. Can anyone help me out with this one?
I have a chassis in a box. Don't know if it works or not. The neckboard has a big burn mark on it, and is missing a transistor that I never replaced. I originally rebuilt it but then found the tube was broken so never got to test it (other than knowing the neckboard was missing the transistor). The neckboard has some big burns on it, and it doesn't look pretty anymore, but it may work when the transistor is replaced. Just don't have a tube to test it with.
Anyway - post a pic of your bad area and later (when I get home) I'll post a pic of the area on mine...
My camera's not the greatest at this, but this should give you a clue what I'm dealing with.
A flat bed scanner might acually work better for the solder side which is what I really need anyway.
Are you selling any of your parts? I also need a yoke.
The yoke on the tube I had was bonded, which is how the tube broke in the first place. Something hit the yoke and snapped the tube off behind the yoke...
Nope. $25 + shipping if you want it. Might work with that transistor replaced, or you could just throw your neckboard on it and have a nice working one - assuming I fixed it.
otherwise, I'll get you pics later...
Ill probably take you up on this. I'm sure between yours and mine I can come up with something that works, assuming I can find a yoke somewhere.
