D9200 sync issues with Blitz
FrankAZ
Phoenix, Arizona
I picked up a used "Damn D9200" on the cheap to put in a Blitz cab I bought without a monitor.
It was fine on every startup for roughly 1 week before I started having sync issues.
About 50% of the time when I start the machine up (whether it's via power switch or going into the test menu), I get sync issues with what looks like the monitor trying to see the board in a different kHz.
I'm not that experienced with monitors and have exercised heavy caution. Was wondering if anyone would know small easy solutions. Perhaps there is something I missed or there is a mode to keep the monitor in a specific kHz?
-FrankCastleAZ
Hold the DOWN and SEL buttons on the remote at the same time until the Factory Menu comes up. Then do a REset of the memory. That might help...
Tried it and it's a no go. :-(
I have the game's dipswitches set to medium resolution which I know the monitor is supposed to handle since it's a tri-sync monitor. I will try setting it to low resolution and see if I get the same errors.
Nonetheless I'm frustrated with this monitor. It looks very clean and bright but it should have some feature to stay in a specific resolution instead of automatically recognizing the wrong resolution half the time.
I can't put this machine in a location as is, as it's too much of a pain to have the location's owner or employee continue to reboot the system manually until it works right.
-FrankCastleAZ
