D9200 has a quarter screen in center.
XcALiBrE
Asheboro, North Carolina
Vertically it's fine looks to have great color but has massive horizontal collapse. I am going to order a cap kit but I'm sure there is something else going on with it.
Picture is below. I only have a relatively standard VOM and usually check continuity with it and voltage to the game PCB's. No clue what setting to use to check on caps or resistors/transistors.
Tested the HOT, it's readings didn't go steady. All over the place. Used an old 9200 chassis' HOT after testing it steady at 6.25 on both legs. Booted it up after soldering it on there and absolutely beautiful picture!
Q425 Collector is connected to the flyback primary windings
That's how you can tell which is the H.O.T
on a tri-res monitor by looking at the schematic
or ask someone. LOL
See website for important details about your chassis.
It tunes you in on the obvious things you should know
like know found fix's in the TSC
you can always add to it as well and keep for your records
next time you get a D9200 series
What have you checked?
