Cyclone Wiring help needed.
Talon2000
Princeton, Texas
Picked up a Cyclone that alot of the wiring has been hacked on. I've gotten just about everything re-wired and working well. But I do have some questions about the two relays mounted under the playfield. Sol10 and Sol16
Naturally the header was burnt on the GI relay, but the other one seems to have had some wires removed, and some stuffed in, bare wires with wire nuts going no where.. This on controls the Ferris wheel, while I have the ferris wheel working properly, I would like to double check my wiring. Since the schematics in the manual don't seem to be a big help, I'm asking for some pictures of the relays showing the position and color wire.
The last and hopefully final piece to the puzzle is the Blue flasher on the cyclone ramp. Sol 7c is it's designation. This has had the wires cut, and I as of yet have been unable to find a plug that this would even connect to. I'm think it may have been wired to the previously mention relay board.
So if anyone with a cyclone could shoot me some pictures of the wiring of those that would be great.
OK. Last request.
Can someone take a picture of the two AC power relays on the underside of the playfield Lower right so I can see how they are wired.
Yes it does..
Although, it doesn't explain why the previous owner screwed the wiring up so bad...
One major problem I can see, and wasn't 100% sure about was the bottom relay board for the GI on mine is the wrong one..
At least now I can fix the last puzzle piece on this machine.. Yeah!!!
Thanks very much.
