Angry_Radish
Continuing to dig into my Cyclone issues, I'm currently tackling lighting..
After replacing bulbs, I have determined my backglass GI lights do not work, and the left side of the PF GI lights do not work as well as the under playfield tunnel lighting for the boomerang.
I've tracked down the backglass GI lights to a bad driver transistor (Q16), but the PF lighting has me stumped.
From what I can tell in the manual the playfield GI lighting is controlled via 1 relay and driven by Q9.
I swapped the relay with the other of the same part# (there are 2 of the same relay boards under the PF) and the problem didn't swap or change.
If there is only 1 point of control for the entire GI for the playfield and one side works, what should my next course of action be?
