Deadpool66
Im wondering since Ive never done this. After you a apply a new overlay to a cp how do you cut out the button holes?
That is the way I do it, apply overlay then use an exacto to cut the holes out.
Not going to add plexi its too damn expensive destroyed the last peice I tried to route. So basically I should apply the overlay and just trim the holes with a razor or exacto knife?
Yep, like pmichelsen said just use an exacto knife. Where did you buy your plexi? I usually buy large sheets from Lowes for like $6, these sheets are usually enough to do a couple of CP's.
Really? My piece of LEXAN I got locally at a Glass shop was like 25.00 and I was able to make 2 CPO and a Marquee. Routing was acually a snap, just use the CPO as a templete and set the depth to only cut the Lexan, not the CP.
I guess I just had beginners luck...
