I have not. I do own a sign shop and if you do as well then it would be cost effective. If you don't have your own gear It might be a little high.
Since I have a vinyl plotter I was thinking about doing this then clear coating over it.
I guess I should mention that this isn't cheaper than painting, only faster. I spent about $100 just for the vinyl on this ms PAC.
Jeff
Seems like just adding the pink back onto a nice original ms pac cab might look nice.
Depends on how bad the rest of the colors are, but it would probably be a big improvement. Pink is usually the first to fade. It may just be lipstick on a pig too.
Jeff
The vinyl went on to the melamine really easily / well. Sprayed a light mist of water with a drop of detergent added onto the cab and also stickers. Allowed me to move about until happy with position. Adhesion was and still is great.
