I don't know how far away from the main PCB I can move the rom PCB without problems, but can anyone tell me the part number for the cable, which is at present about 4 inches long, so I can try to find out how long I can get them?
QUOTE]
Digikey
www.Digikey.com sell connectors & made up cables that look correct - have a look at the connector specs pdf doco on catalogue page
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=CPC40S-ND for the rom board connector.
I measured up the rom board connector on my Defender ROM board (Presumeably the same connector is used on the Robotron ROM board too.) and compared it to the CPC40S-ND connector. I used my Micrometer the check the pin spacing and sizes and the specs match.
There are also made up cables using those connectors - go to the home page
http://www.digikey.com/ and search for "C3APS-4006G-ND" for a 6" cable, and "C3APS-4036G-ND" for a 36" cable (there are other sizes listed in the table
http://dkc3.digikey.com/PDF/B092/P0036.pdf )
Can anyone confirm that the aforementioned Digikey "C3APS-4006G-ND" or similar cables are suitable for the Defender/Stargate/Robotron Rom to CPU board connections ?
Cheers.
Ok. The last post in this thread was a few days before my injury, surgery, complications, hospital stay, and all the other garbage that happened afterwards.
So I'm back to trying to figure out what I need and where to get it.
The following 40 pin cable should work between the main and rom PCBs:
http://www.digikey.com/product-detail/en/C3APS-4006G-ND/C3APS-4006G-ND/1123437
Then there is the 20 pin ribbon cable that should work between the main PCB and interface PCB:
http://www.digikey.com/product-detail/en/C3APS-2006G-ND/C3APS-2006G-ND/1123419
Now Bob Roberts sells the following:
Wms Ribbon Cable Main PCB to Rom PCB $9.50
Wms Ribbon Cable Main PCB to Interface PCB $8.50
Wms Ribbon Cable Main PCB to Speech PCB $9.50
Can anyone explain the need for a ribbon cable between the main and speech PCBs? (My boardsets do not have this).
Lastly, since I also need to crimp my own 40 pin IDE (and 20pin-whatever it is called) can someone tell me the search terms needed to find the connectors on Ebay and the tool needed to do this?
Thanks.
Darren Harris
Staten Island, New York.
