Custom Neo Geo Mini Marquees
Redo Magician Lord!!!!
Thanks!!!
Ask and you shall receive.
Before:
After:
Love the custom mini-marquees!
I took the arcade flyer and did a quick custom mini marquee myself. Just adjusted the layout and removed some elements that I wouldn't be able to read anyways. Here's how it turned out:
These all came out really great!
I noticed on your hosted link to your OneDrive didn't include the Neo Bomber Man - that one was my favorite you did. Any chance of getting a link to the .jpg for easy printing?
Thanks!
Thanks!
Sorry, I missed this before. I actually lost that file and will have to recreate it once I get some free time. :(
Not sure how I'm just now seeing this. Awesome work! Any objections to having your own gallery/collection on Arcade Crusade? I can set it up where you can upload the high res versions directly and manage them that way :)
Totally forgot you had mini marquee section on the site. Haha. I have an old account where I posted a few arcade albums. Can I use the same account to post to the Mini Marquee section?
Yep. All I need to do is create the folder and grant you access to it. I'll make a note to check it out tonight. I'll let you know when it's setup.
That's really cool. I just figured out a way to make translight material look like vibrant silkscreen colors this week. I made Metal Slug, Puzzle Bobble, and Samurai Showdown. I think they came out great.
You have a sub album in the mini's section now: http://www.arcadecrusade.com/gallery/v/minimarquees/nesjess/
Your old login should have access to add items (pictures), sub-albums, and also edit and delete items. The standard for these has generally been TIF files at 300dpi, if I remember correctly. The only limitations I am aware of is that the server will only allow single uploads up to 7MB in size, so that means only try to upload one at a time and make sure they're under 7MB. Otherwise, that's it :) If you can't edit the album details (description, etc), let me know what you want there and I'll update it.
PM me if you have any questions or trouble.
mystery method
I second nessjess - how you do dat? :) I've experimented with a bunch of different paper weights and lamination, but never been perfectly satisfied with the result.
I looked at your OneDrive and noticed some 10MB PSDs so this could be an issue with the current gallery software. Flattening the PSDs and saving as TIF might lower the size enough to upload, I'm not sure (though I can check when I get home).
As some of you know, I'm moving to other software soon for AC, so hopefully I can find a way to up the size limit per file...I think it's a setting in the PHP configuration though and the last time I tried to modify it, it didn't work. Worst case, I'll contact my host and see if they can point me in the right direction or if it's something they need to do.
