Custom control panel
Reddogg
Upland, California
Does anyone here make custom control panels? I have a machine I want to turn into a MAME unit, but I need either a custom wooden, metal, or other, control panel for it. It's a simple rectangular shape, approximately 10 1/2" X 23 1/2", and I need all the holes drilled out including screw holes, bolt holes to the cab, two joysticks with 6 buttons each, and trackball in between, and both start buttons. Again, all I need is the control panel, and the holes drilled. I can install everything else myself.
Can anyone do this, or know someone who can?
Thanks.
2 player 6 button setup with a track ball?
Honestly that small of a control panel I don't think you could fit in a track ball.
It'll be tight, but with a small 2 1/4" to 3 1/2" trackball, I believe it will fit okay. It's for home use, so doesn't have to be perfect.
