Crystal Castles power switch replacement
Aquasun
Greenwich, New York
I have a Crystal Castles project cab that was converted to Tetris. The power switch is bent and doesn't switch properly, and after further inspection the inner plastic part is dislodged and has a little broken cap in it. That's the only problem I've found with the cabinet so far; does anyone know where to get a replacement switch and which one to get? I found these: http://www.twistedquarter.com/index.php?main_page=index&cPath=4_48 but am unsure which one I need. The current switch has 4 pins on it I believe. Thanks!
