Does this exist?
My search fu is coming up blank.
Interesting. I guess I could have drain bramage but I thought it just sits at the press 1 or 2 player screen. Guess I will have to test it further.
Mine just sits on the freeplay screen as well...
Mine does it without modification.
open the coin door, switch the self test switch, and change it on the menu screen. done
I actually started working on this awhile ago, but I got busy with some other projects so it got put on the backburner. I'd never worked with 6502 code before, so it was done just as a learning exercise. I don't even own a Crystal Castles.(although I want one) I have some of the disassembled code commented and most of the relevant memory locations identified, but there's still a ways to go in figuring out the subroutines and program flow. I should actually start working on this again. If anyone here has experience with 6502 stuff, or ROM hacks in general and would like to collaborate on this, please let me know.
Not a ROM solution but a CoinUp-1UP would work.
