Cruis'n World, operates, no start
BobsterD
New Mexico
I have a Cruis'n World that will boot up, take credits, but wont start when you hit the button. I've checked all the typicals... switch, plugs, wirings, etc... no luck. has anyone come across this?
Also, I can't find a manual anywhere or on ArcArc. Anyone have one in PDF?
Thanks in advance!
cruis n
Have you gone into the setup menu and verified the operation of the various buttons and controls on the game? Also check your coin in set up menu.
RJ
Attract loop runs and looks fine I take it?
If so, you probably have an I/O or wiring issue. Trace the start button back to the boardset and try shorting that point on the board (underneath the connector) to ground. (Careful -- easy to cook something if your hand slips.) If that starts the game, you have a wiring / switch problem. If it doesn't work, you have a problem in switch input on the boardset itself.
I'll go into the setup and re-check all settings. The attract loop appears to run fine and looks ok. I also now notice it seems to be stuck on 30 credits.
