amr
How is it mounted in the cabinet?
I have had no luck getting vga converters to work with med res monitors. Both narc and cruisin use med res and the both look great .....for a while, then they fade to a solid color after like 15mins. When I reset the converter it looks great then blank...have tried 2...same brand (from jammaboards.com). what kind of converter did you use and where did you get it? I hate messin with this med res crap. I know you know what I mean...If it looks nice who cares how pure it is...I have used them in other games even ms pacman...guess what looks awesome!!! oooo you think cause it's a TV not a pc monitor
Set your Clamp st to 3 and Clamp sp to 4 and it should fix that issue. I had the same thing on a GBS-8220.
Old thread I know, but I just picked up a Cruis'n and it's playing blind. Not really a fan of LCD's but in this case it seems like a great idea.
I'm curious since it's been about a year, is your's still going strong? Is this the adapter you are using?
http://www.ebay.com/itm/New-RGB-CGA...029?pt=LH_DefaultDomain_0&hash=item231fa2df35
Also did you use a vesa mount, or did you fabricate your own?
Just got it in, and I concur with the OP...
