JMK99
Hi: I'm new to this forum, so hopefully, I have posted this question/thread in the correct place:
I recently acquired two linked Cruis'n Exoctic sit down arcade units.
For some reason, the speed/acceleration is slower on 'the slave' unit for all of the vehicles.
The cars on the 'master' unit reach speeds of approx. 30km higher than the cars on the attached linked unit at top speed.
Also: when I go to calibrate the steering wheel on the same 'slave' unit, it doesn't seem to calibrate perfectly straight. In other words, if I calibrate it 'straight' then during game play, it won't allow for full right turns. However, if I calibrate if slightly angled to the left of straight, it seems to help to remedy this particular problem. Is this a problem with the steering wheel not being aligned properly?
Any help on either of the above would be greatly appreciated.
