cruis'n everything is reversed?
djdaveofkc
Gardner, Kansas
Ok guys, my cruis'n usa to exotica driver, i had taken the steering dash out to test in another unit as mine worked great. Everything was fine on the other unit so i put it back. in mine. In the meantime i got a replacement pcb(exotica). This is where the fun starts. on the test switches, the 2 middle don't do the volume or select from the test menu. They bring up the keypad on the monitor. The brake and gas are reversed. when i start a game the steering of the car goes to the right and won't turn back(even if the wheel is turned to the left). Force feedback is gone and the volume is full blast. What the heck did i reverse on my wiring etc to make all this happen to a working game??? thanks
My understanding was that Exotica was not interchangeable with USA and World. Totally different pinout. Do you have the manuals to compare?
ok, dip 1 was not set right. now the only issue is my wheel is pulling to the left during the test, and no feedback during normal gameplay. Gettin closer!
