Cruisin USA has no wheel feedback? No lights also
kjeffery
Walcott, Iowa
Just got a cruisin usa and it plays great but the force feed back isnt working along with all the button lights. Im sure all the lights cant be blown. The wheel driver pcb lights up and looks like everything is wired up right but I still dont get any action from the motor. I have tried a different motor and that didnt help. Any ideas?
Assuming you have a dedicated sit down cruisin', the force feedback motor is, iirc, 110ac. Make sure you've got some kind of voltage over there. Also, I know on the older rush cars, the wheel driver transistors had a tendency to blow out. Try replacing the driver transistor on your board, that may correct your issue. As far as the lights not working, check the bulbs first, as this is the easiest solution to your problem. Just meter them out, if they're good, then check the wiring. Make sure you've got your voltage there, and just track it back. If they're all out, I would think you might have a bad ground, as ground would be common to all the lights.
