CRT neckboard socket pinouts for rejuvinators adapters
baritonomarc
Mestrino, PD, Italy
Hi all,
i was wondering if there's a reference for neckboard sockets in order to build up adapters for tubes rejuvinators (mine is a Promax). IIRC BK precision reference has some pinout, but how pins are enumerated? from left to right looking at the solder side or "pins" side?
Some image would be of great help ;)
Thanks!!
ok, let me be more precise: i have an Hantarex MTC900/E i wanna rejuvenate. I found "here and there" that the right (B&K) connector is the CR-23. Then, i cross-referenced the tube VS connector data i own for my rejuv, and found that the right one should be A8... the problem is that that socket could not be inserted in the back of my tube... O_O
now, it would be very useful for me if someone could post a pic of that connector and, eventually, the pinout jut to see if i have an "odd" tube or whatever (the ID sticker with the number of the tube has gone :_( )
Some Hantarex monitors use the CR24 instead of the CR23. If you post a pic of your neck I can most likely ID it.
There is a drawing of the CR23 adaptor in this folder. I forget how it is marked, and I can't access the website from this computer (the site is blocked at work), but the pic is here: http://arcarc.xmission.com/PDF_Monitors/
Now, if you'd like to see the CR series pinouts then just reference the last few pages of this document. http://www.bkprecision.com/support/downloads/pdfs/CRT_Setup_Chart.pdf
Thank you for the links. From the B&K reference looks like CR23 and CR24 have red and green swapped, but mine sais that they have the same pinout. Anyhow, i dont think that swapping colors pins could be a problem :)
I cannot take a pic of the socket being unacessible ATM, but i can show you how the socket that fits it and i am building the connector from is (attached)
Could you confirm this is a CR24?
