modessitt
Any problems taking one OFF of a chassis that has one? I have a strange brightness issue with a K7000 med-res that has one installed. The game is not a shooter, so it's really not needed, and I'd like to pull it off to see if it is the cause.
Basically - I installed a new flyback, have a good picture. If I turn up the brightness on the flyback, the screen gets washed out and I get raster lines as expected. but if I turn the brightness DOWN the picture gets really bright for a bit and all the colors bleed and then a little later the brightness goes down to black as I continue turning the pot down.
I'm sure it's not the flyback, and would like to remove the brightener to see if it is causing it....
