Crt auto degaussing help!
jmac
Donor 2012
Hello everyone,
can someone help me with my monitor, its a Ceronix 1993 vga crt And it appears the degauss isn't working, is there a way to test the relay on the monitor chasis?
  • 1993VGASCH.pdf
Heres the chasis schematic
  • CPA4287PAD.pdf
The degauss circuit operates for only a few seconds when power applied to the chassis and will only clear up a minor magnetization. You may need an real degaussing coil to fix your problem.
That said, you can test a relay by applying voltage to the coil (preferably through a current limiting resistor) and then measuring the resistance across the relay contacts to find out if they are making contact with each other.
Awesome thanks for the info!,much appreciated.
John,
