Creating MAME errors to help fix PCB errors
Radford119
Donor 2011, 2023
Indiana
Does anyone have any experience in purposely creating errors in MAME ROMs to help diagnose PCB issues? Is this a viable method to try to target PCB issues? I have seen braze's example regarding his DK error screens, but what about modern boards? Can you simulate a RAM or CPU failure?
Sorry for the mass amount of questions and thanks for any info you guys have.
I've done this. I usually just keep a 0 KB file sitting around in the ROM directory of the board I'm working with, rename the original ROM, copy the 0 KB file to the original ROM name, test. If I need to try the next ROM, I delete the 0 KB file, rename the original ROM back and move on to the next one. You can move through a board pretty fast this way.
I usually keep two DOS windows open, one with the copy/delete/rename commands in the keyboard buffer and one with the MAME command. Then you can launch quickly after modification.
I haven't figured out how to mimic a RAM error yet.
Edit: From a command prompt, you can create a 0 KB file by typing 'copy con filename.dat' (without the quotes). Then immediately hit CTRL-Z, and it will write the file. Filename.dat can be whatever you want the file called.
Not sure what MAME does when it gets a 0-byte file in lieu of a finite size file. I'd guess it fills (or leaves) it zeros (0x00).
According to Scott Brasington (http://www.brasington.org/arcade/tech/mame.shtml) an EPROM is apt to fail such that it always reads 0xFF.
You favorate binary editor (or perhaps EPROM software allows editing/filling the buffer) can do the job of creating you a file full of 0xFF. Presumably it would be handy to keep a set of files of common EPROM sizes (2kB, 4kB, 8kB etc.) filled with 0xFF.
All that said, I've never used this technique. I'd rather just read & verify the EPROMs.
I've used this method heavily when working on boards with surface-mount ROMs or mask ROMs where I'm uncomfortable removing them (fragile) or unsure what to read them as on my burner.
I've not seen an issue just using the 0 KB filler, but I've also not tried it with a filled ROM image (all FF).
