Scucci
I have a Falcon Crazy Kong (Part II) board here that is producing no sounds from the EPROMs. There are still sounds from the game, but not that are stored in the EPROMs. The basic music, points sounds, hammer hitting something sounds, and basic melodies are all there, but they aren't reliant on the EPROMs.
I pulled the logic probe and started checking around and I'm seeing next to no pulsing in most of the audio EPROM section... off the top of my head the only pulsing I'm seeing is on the 7402 at 2S and only on pins 1A, 2A, 3A, and 4A, the outputs are working as intended (as best I can tell, more coming up on that) and the B's are flopping back and forth as sounds SHOULD be read from the EPROMs (walking, barrels falling, jumping, thuds, etc). The only one that's not flopping is on the first NOR gate with pins 1, 2, 3. Even though the inputs are pulsing and flopping, the output on that one (1Y) doesn't change. I thought it was the chip, but I replaced it and it's still acting the same... It could just be switching at the exact right moment and not causing the output to change...? I checked that pin, in socket with no power applied, and it's not shorted to anything. So the 02 and the next chip in line with that (and 04) should be good?
I have piggybacked a known good Z80 with no changes at all in the missing sounds (figured I'd atleast get some jibberish).
Any more ideas on what to check?
