Crazy Climber Repro Marquees Available
mgreen
Donor 2012
Idaho
Crazy Climber Repro BEZEL Available
I stumbled upon this website for repro artwork for the bezel. I know it is not original or NOS but would look really good for the daily play while the original sits in storage to prevent further decay. You need to be press the graphic onto the glass yourself and you can choose top or bottom glass styles
http://www.gameongrafix.com/products/crazy-climber-bezel-1
I believe they call that a bezel ...
At any rate, I know there are a lot of people out there looking for one.
Steve
MM
I don't know if Scott has spent time cleaning that image up or not. I've been planning to do just that for quite some time and have Rich print it for me. But it probably would be worth checking into the quality of Scott's before I do that.
Hah hah hah. Can't believe I did that. Bezel is much more rare so I was trying to get the word out. Post updated.
Steve
MM
I got one of those bezels and I'm very pleased considering it was only ~$50 shipped...
I used a flash for the pix and it makes the repro on the right look a little darker than it really is. I also put it over the monitor real quick with a new plexi on top so it is not perfectly installed in the pic. Here is another pic for more comparison:
The bezel comes with a white fill section in the middle that has to be cut out. That was easy enough to do with a sharp razor and good metal straight edge. You can also see that the repro has a uniform black fill in around the edges where the original has a very complex edge with objects overlapping into the clear area. I might try to cut out the black filler, but it will be tricky and some things in the clear view area are not attached to the scene.
i honestly have never saw a 9/10 shape or perfect crazy climber bezel. never.
