wrongdon
This is sold .
Cab is solid , no water damage , it is not all hacked up . It has been converted to Konami something or other but they retained the original power supply re used the original harness . Putting a new edge connector on the harness and wiring it for Crazy Climber should do the trick . It has a G07 monitor inside , untested . The lower coin door is not pictured but it is here . The control panel is original though hacked , I believe one of those metal overlays from Ebay will fix it right up . Back door is in good shape and included . No marquee but the bezel is included , it is not in the best shape but is acceptable . I have a boardset that i wired in a crap cab a few years back and it worked and played back then , on a shelf for a good year now so consider it untested .
$350.00
Located in Wellington , Ohio , 44090 .
The sooner it is gone the better , bring a trailer and snag my Blasteroids , Kickman and slant top slot while your here . I'd make a pretty good deal on all of it gone at once , need the space .
Don
$350.00
Don
