Well, I do play CC frequently and I can reach the 3rd building but haven't made it to the 4th yet, but hopefully I will by then. Getting to the 2nd building is plenty though to surpass the default high scores of 20,000, so hopefully you'll consider me qualified regardless.
If so, LMK how much and I would be more than happy to test, give feedback, and burn new images as needed.
I did find Tim's page again and it seems like it's not worth making his adapter board if I will ultimately get a board from you. I also think I could live without the better letter navigation if high scores are saved because obviously after a while games would result in a high score only occasionally. Still, it would be nice to have. I may consider integrating his navigation change at a later time if you don't do it. Hopefully that's not the change that introduced instability. And are you sure it's one of the mods themselves that introduced the instability and not a failure to decrypt the roms 100% correctly?
BTW, I think the thing that will take you from "suck at the game" to halfway decent is the realization that you don't have to avoid getting hit by the falling pots. As long as you're holding on to a window ledge with both hands, they won't knock you off (unless 2 hit you at precisely the same time). They will alter your position though so my habit is to hold both joysticks downward. That way if there is a 2nd pot coming, you're still safe.
