kentmurphy
I purchased a CR7000 a few weeks back and used it for the first time today on a Matsushita. The unit seem to work fine, but unfortunately all it told me was that there was a G1 short to the blue gun. I tried removing the G1 short several times, but no luck. The manual indicated a spark should be seen as the short is removed, but I did not see one. Assuming the CR7000 is working correctly, there must be a mechanical short which cannot be removed.
How would I validate the CR7000 is working correctly? I didn't see a self-test procedure in the manual.
I do have to say one thing. The documentation for the CR7000 is fantastic. It's easy to understand and it is laid out in sequence hence it starts first with setup, then tests, and finally the restoration procedures.
