Cr31 adapter for bk467-I want to make one, anyone have the specs?
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
I loaned my cr31 adapter to someone, I forget who, now I need one, haha.
Can someone point me in the right direction on a build?
Finished it up but I am uncertain if the white wire (pictured) is actually position #1?
Picture of front. I used the wire color suggested in Ken's link to avoid confusion.
That's the focus spark gap pin, not to be used. The actual focus contact is the hole on the top (you just push the stripped wire in, no soldering).
Right on, thanks.
Well the spring loaded little switch that seems to hold the wire snug in place seems to be broken.
I'm using a piece of excess flyback wire I removed from another flyback.
The wire goes in and out far too easily.
Edit: I installed the white wire, attemped to make the me hanism snug, and crazy glued it.
I am a little hesitant to go test it. I may have a junker tube I can try it on first.
I think the worst that will happen is that the FOCUS fault indicator on your rejuvenator will light up (assuming the rest of it is correct).
If you're not sure about that one connector, you can check continuity from the pin on the plug to the contact in the CRT socket.
if you have trouble getting it to work,
you can always buy one made by a pro;):)
keep us posed on your progress.
Peace
Buffett
Peace
Buffett
Sorry yeah, it worked fine. Now I've got the machine open doing an overhaul, waiting to get some 47uf 450 v caps for it.
