What voltage lines are necessary for CPSII?
+5VDC
+12VDC
Any other? I ask because the power supply in my JAMMA cab took a dump last night... a couple weeks ago my 18-in-1 CPSII board stopped working for no reason... I only got the menu (the add-on board runs on +5VDC).
I swapped in a 1940-in-1 on Monday morning and it worked fine (+5VDC and +12VDC required I do believe) ... but died a couple hours in...
...I wonder if, say the -5VDC line died earlier and the CPSII board needed that voltage? Just checking to see what voltages it needs on the miniscule hope that the boardset isn't in fact, toast.
Thanks!
+5VDC
+12VDC
Thanks!
