CPS2 Sound Issue
ThunderBunny
Winchester, Kentucky
Anybody ever have an issue with a CPS2 board where the volume would turn down by itself? It would turn up and then slowly go back down to nothing. I swapped A boards thinking it was the problem. Unfortunately it's not that easy. It's an Aliens vs Predator board that I changed the battery two years ago. Any ideas?
Maybe the button is stuck? I've had this happen before. Also noticed that if I change a few settings on one game (like free play or volume) and change the B board to another I often have to change the settings again.
That was my thought too. Swapped the A board and still the same issue.
I think there's a button combination you press when powering on, it resets the volume or something to that effect. try either pressing down or both up and down when you power the game on and see if that helps.
