CPS2 18 IN 1 Help? What am I looking at?
squall280
Pennsylvania
Ok the plan was to put the bottom board in my dead case so i could provide some cooling on it(since they are known to get hot). with lack of instruction i was curious as to what exactly are the wires for since they are not on my original board and also what is the other smaller board for? i dont; feel like just pluging in and seeing what happens. can someone assist? also is it ok to cut the zip ties that are holding all the boards together?
The wires are for the extra buttons if you have a kick harness you don't needem. the extra board plugs into the cart and then into the jamma harness it has to be plugged in to access the game change menu.
I would just leave the top off.
so leave it zip tied? and just leave the bottom piece of sheel on for the fan uses and don;t contain the boards?
