CPS1 boards from AliExpress
Can you post a Pic of what you are talking about. If it works 100% what is the problem with a slightly different part?
If it works, then great. There have been many documented cases where it doesn't last very long.
If you do some research there are a lot of threads on the arcade-projects forum about this:
I personally bought a couple for funsies. One worked fine for a few months until it didn't (see thread above) and another worked, but there were sound issues with muffled sounds
I got an exchange for the non-working one. The other I eventually just repaired by replacing the entire audio section from a donor board.
The point of me asking in your other thread about the boards is just to see if yours is also another example of a non-original audio section. Basically to let people know that's the risk of buying from these sources.
Again; if it works to your satisfaction, i'm happy for you. The truth is all CPS1 boards are sorta on borrowed time at this point, given the large number of A01 custom failures.
