Cps1 A board no video, coin op sound only.
ovalfastlx
California
I have an A board with street fighter 2 hyper, the B and C work, I tested on another A board.
The A board only has the coin op sound when they coin switch is triggered. no other sound or music. I only get a flickering white and sometimes purple screen that stays on the top on monitor.
checked cpu reset, Halt, clock and everything checked fine. I have a logic probe. I have run of things to check maybe someone has suggestions?
I know the custom chips go bad on these board. Trying to identify that issue and rule it out.
Thanks guys and gals, I'll post up pics later if that helps.
Basic troubleshooting steps:
1) Check for power at all chips
2) Confirm no floating lines anywhere (need a known good board to compare against)
If all that checks out, then the only thing left is to swap the CPS-A-01 for a known working A-01. Dead CPS-2 A boards are a good source for CPS-A-01 replacements.
