CPS-2 Test button
rcproam
Columbus, Nebraska
It says in the manual to hit the test button on the side but mine does nothing,neither does the volume + or -.It's in a alien VS predator machine.Is because there are wires cut in the harness looks a little hacked.How can I by pass it to get to test mode?
You can get to the test menu by hitting the test button on the side of the A board, or by using the Test button on the JAMMA harness.
worst comes to worst, u can connect pin 15 to one of the grounds with a piece of wire... you could also try using a different A board.
