CPS-2 kick harness connector size?
modessitt
Austin, Texas
I have to build a kick-harness connector for an X-Men Children of the Atom. I would order one from Jammaboards, but they are moving their shop and won't be back up until after the weekend, and I need it ASAP.
Anyone know what connector to use, and the pins to use in it?
Thanks. I found a 30-pin connector here in a box that I can use, since pins 1-8 aren't used.
I just need to make sure, when looking at the connector (with the blue side facing up), is pin 1 in the top right position, with pin 2 below it like this:
1 3 5
2 4 6
Or is it like this:
01 02 03
18 19 20
Or is pin 1 on the bottom?
Thanks...
FWIW it's the same as a computer IDE cable. I made my own out of an old IDE cable once. Think I had to file down the edges to get it to fit, though.
