CPS-1 - Male side of kick harness connector
NoAffinity
Does anyone know what the make and model of the male side of the kick harness connector is, on CPS-1 boards (like SF2)? The side that is soldered to the 'C' board, which the kick harness plugs into. Is that a JST connector?
Any help would be appreciated!
I realized you were looking for male header part?
> http://www.digikey.com/product-search/en?mpart=76650-0207&vendor=23 Male End (Right Angle) not sure if this will fit c board
> http://www.digikey.com/product-detail/en/molex-llc/0022232101/WM4208-ND/26683 Male End (Straight) & >http://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/1-640456-0/A1925-ND/27157 different vendor but same part , specs match 10 pos .100
> http://www.digikey.com/product-search/en?mpart=76650-0093&vendor=23 Female End
Same as above but straight thro
I was able to find the female end at frys locally ... I never looked for other end...
picture attached is one I found at frys and it plugs into my sf2ww board just fine
hope this helps
Nice! Thank you both!
I've got bent pins on all 3 of my SF2-series boards. The female side is pretty unforgiving and still fits on the headers, but it's looking like one or 2 of the pins might break soon, and I want to be prepared to do quick repairs if needed.
Thanks again!
Just a note, but he originals are JST NH which are 2.5mm. The Molex ones list above are 2.54mm. Might work, but may be a little tight to fit in the holes. You should put something on your board as well mentioning you changed it in case you get rid of the board and the next person has trouble.
I'm also trying to source the JST's, but am not having any luck yet. Anybody know a good source?
I looked up the housing and they had them. Didn't try the header as I didn't need one of those.
Did you try the whole part number? Did you search in the store?
What's the whole part number? I searched in the store for ISTR and came up with nothing. I e-mailed their NA e-mail contact as well. hopefully get a response soon.
I got a response from JST USA, and they are unable to identify what part I'm looking for, based on the part number NH ISTR. Any other suggestions as to how this pin header is identified (part number)?
ISTR isn't the part number. ISTR is internet short hand for I Seem To Recall.
NH is the name of the part series.
Header is part number B10P-SHF-1AA
Housing is part number H10P-SHF-AA
Pins use in the Housing are part number SHF-001T-0.8BS
lol, d'oh.
Okay, thanks for the part numbers!
