ThisOldGame
A couple of notes:
- Jasco will give you comparable results in that situation, though with terrible smell, and you don't want to get it on your hands or clothes
- On this strip you have the advantage that there is PAINT below the glue. Paint is easy to strip off of metal. Glue directly on the metal? Not so easy.
I'm currently dealing with a Frogger CP where the CPO was glued directly to the metal and I've tried everything and I'm making sloooooooow progress toward getting all the glue off.
Yep very true differnet products give you differnt results becasue of these factors.
and even if a panel is powdercoated will add another exception to the rule.
keep in mind most of these adhsives used were made by 3m
and were designed to be both chemical and heat resistant
