couple of questions.
BoFoSho
Donor 2022
Honesdale, Pennsylvania
just got my donkey kong and it seems different than any i have seen.
first it has the ladder cheat,second the boards are on the right of the machine if you are looking from the back of the machine, next the bezel has 4 screws in it at the bottom, there is a piece of wood that is about 1/3 of the way up from the bottom of the machine that has the power supply on it. it also says how high can you try instead of how high can you get.
any idea's what i have?
How much is the pcb worth?
Question: are you from a country other than the US or Japan? That doesn't look like any Donkey Kong I've ever seen, it may be a European model or something though.
I was thinking someone turned an R-Type into a DK. Let's see a side-profile of the cabinet...
