could i turn bad dudes into nfl blitz??? or what other cool game??
INOVERMYHEAD
Ohio
could i turn bad dudes into nfl blitz??? just have to add a button and the screen would shrink to fit the 19" monitor right??? It would be shown on a 19" horiz. instead of a 25" horiz. , but wouldnt it just shrink to the size of the monitor. . ???
you can plug all kinds of games in a jamma cabinet.
Yes, for NFL blitz you need 3 buttons.
The blitz boards have dip switches on them to set the monitor to STANDARD resolution and STANDARD 8-way sticks, which you will need to set in order for your game to work properly.
Monitor size doesn't matter. The image will be fit to the size of the monitor. NFL Blitz works with standard resolution monitors and medium resolution monitors.
Blitz also uses a 49 way optical joystick, so I would buy 2 of those if I were you. I'm not sure if you can use an 8 way joystick for blitz.
...nevermind I just looked it up, you can use an 8 way joystick. Just set the dip switch 1 to off.
I would buy 49-way joysticks and you would need an additional harness to connect the joysticks to the pcb itself.
Though you could use them, 8-way joysticks suck ass for this game. Trust me...
