corrosion
blitz_8255
Pennsylvania
What do you guys reccomend for removing and stopping the spread of the battery corrosion from bally mpu boards?
Chemicals?, little wire brushes?......
Corrosion is pretty awful. Slash and burn. Being careless will only come back to haunt you. It's much better to be overzealous and replace more bits than you need, than to do the reverse and miss one. I usually trace the circuit down and pull the adjacent "clean" parts next to any corroded ones, just to be sure I don't miss any.
thanks G-P-E for the awesome read/link and FireSlash for the headsup on never being to careful! Board has been cleaned and the parts for repair should be in today!
