Correct probe for Sencore CM2000 Computer Monitor Analyzer
Patrick Verner
Donor 2019
Waupaca, Wisconsin
I need the Ringer Test probe. Not sure what the correct probe would be. Can you run an arcade monitor with the Sync & Video output?
https://www.ebay.com/itm/405559588406
If you aren't interested in purchasing this set, you can use the picture to build your own: Grab a coaxial test lead with BNC on one end and split out the center conductor and shield to individual clipped leads on the other end.
Another option - purchase a commercially available lead from a reputable supplier - such as this one from Digi-Key.
Thanks! I didn't know if it was a direct lead or not. I found this one on ebay.
