Corner repair: Bondo vs PC-Woody?
ajcrm125
Massachusetts
I'm about to repair a couple of Nintendo cabs I have. For cab repair in general I've seen people use both PC-Woody and Bondo. Is there a preference and why.
Thanks!
Bondo all the way.
If the corner is missing a pretty big chunk then use small screws to reinforce the bondo.
Bondo but beware - stuff is a bytch to sand, etc. so don't leave a lot of excess on there thinking you can just sand it away easily.
Bondo works wonders but I take into consideration what kind of corner is missing.
Nintendo cabs with bases = Bondo all the way
Williams Robotron cab = replace with plywood and Bondo the seam
Otherwise your freshly painted cab is going to have a freshly broken corner the first time you move or bump it.
