Converting Gauntlet Legends
beerbarrel
Warner Robins, Georgia
So, I was thinking of selling my Gauntlet Legends and then thought I might convert it to a different game. What can it be converted to and what is a game that has good replay value that will work on the boardset?
Thanks,
Tracy
Other than dark legacy, sportstation is the best game on the system, but you need to change the video card(and rotate the joysticks).
Cab is jamma. If you monitor is tri-sync, you can change joystics to 8 ways and play a ton of games in it. Otherwise its very limited with the 49 way sticks.
I have a tri-sync monitor in mine and I swapped the joysticks with 8 way Eurostick ILs and have been very happy with this.
I also have NBA Jam boards in the cab which I swap to via a JAMMA extender harness in the CP. Takes less than a minute to swap games and it works 100% with no issues. Have to tweak the monitor remote adjustment board too but it's also in the pop-up CP so that's no big deal.
You can also upgrade the GL to GDL pretty cheaply. I'm about to do that myself.
